Droid X2 Power Button Problems
Mattfox27
3
I just went from a Droid X to the X2 and i have noticed that the power/unlock button seems harder to press then the droid X, it seems like it doesn't stick out as much as the X also...Anyone else notice this?
I can't tell any difference in the power button on my X and the power button on my X2
Sent from my Xoom using Tapatalk
My Nexus S was like that, after using it for a week it got a little more easier and broken in.
It does seem a little harder to push and not as responsive as the Original X. I have noted that the Original starts it's boot quicker than the X2 upon pushing the button. You have to hold the X2 button longer than you did for the X for it to start up.
Take to a Verizon store, compare to others there. More than likely it's a bad unit; remember, it has working parts and is assembled by man. There is bound to be a percentage that are put together wrong or have bad components. If it were me it would bug me everyday and I would never be satisfied.
kiki2025
