EasyTether Pro won't install on PC
It may be that your computer is set to block unsigned drivers. Here is a fix for that from JuneFabrics. Will not hurt to give it a shot as it is directly related to the exact error message you are getting.
Your computer system is set to block unsigned drivers. You can go to
Control
Panel->System->Hardware->Driver Signing and make sure it is set to
allow
It works! When I looked at the driver signing, it was already set to allow, but the "Make this action the system default" wasn't checked, so I checked it. Then I tried installing, & it failed with a different message. I tried again, & it installed successfully! PdaNet connected just fine.
I want to thank you & all for all the assistance & patience! I'm sure I'll be back with other questions. :)
Gary
No problem Gary! Im glad you were able to get it working :)
More questions? You know where to find us, lol.
PDANET USB Drivers for Android Mot X
Control
allow
You're a damn genius!! I've been working on this for two days on my XP notebook. I read your Control Panel suggestion, made the change, and the installation completed without a hitch. Many thanks, DD.
i think i have the same prob with blocking unassigned drivers but i have windows 7 and i dont know how to do Control Panel->System->Hardware->Driver Signing and make sure it is set to
allow im trying to install the pc software for easy tether
please help!!
-evan
HI DroidDev,
great post, I made everything, but sadly it still does not work.
When trying to install easytether it say: heavy error 0x80070643.
Any more tipps?
Thanks!
racoo
