Droid Razr Maxx was encrypted, as well as the SD card. A failed Android update required a factory reset. After the reset, the SD card was corrupted (obviously). A SD card format later, I attempted to encrypt the phone. It says it worked correctly. Going into the system settings/security & screen lock/screen lock shows only pin/password options available, the others greyed out due to the encryption. Under data encryption, both options are checked.
But, when I turn on the phone from a full off, no password prompt comes up. I am never prompted for my password.
I've tried to unencrypt/encrypt. I've tried switching PIN to passwords and back, trying to get it to catch. No help.
Is the encryption in place and working? How can I confirm? Is there any way to fully encrypt without having to factory reset again (the last time was not convenient).
Android 4.1.2
98.72.16.XT912.verizon.en.US
Android 4.1.2
