Epic 4g front facing camera issue.
seoantae
5
Hello. Guys.
I have a problem with my epic 4g front facing camera.
When I take a picture with front facing camera, it shows some partly crash image on the side of picture.
Does it software problem? or hardware problem. I'm not sure it happens after update EI22 or not.
The main camera works well.
Any help?
Are you running a stock rom?
If you are, than I am leaning towards a hardware issue. If not, could be a bug in the camera software of whatever rom you're running.
I've rooted and use other rom before EI22 upcoming. But now my phone is unrooted and use EI22 rom. And also front facing camera's performance get worse than previous rom. Darker and sometime it blinks.
IreneSaenw
