Epic battery life settings
vladydady
For those that are getting 10 plus hours of battery life with heavy usage can you post your settings? I force stopped the media hub and the drm copyright. I also put my set my wifi sleep settings to never and my brightness display is at the lowest setting. I also have background data and auto sync turned off too. Please help!
I use an app called Quick Settings that you can get off the Market to disable my 3G when I'm home and only use/turn on the WiFi when I need to browse the web, get updates, surf the Market, etc. This alone seemed to DRASTICALLY improve my battery life.
If you do decide to try this out please post back, I'd like to hear some feedback to make sure that it's not just me and not a placebo effect and that it actually helps the battery some.
Opoliraka
