error validating footer(6)
  • Start date Start date
A
Android Central Question
i was updating my s10plus software when a screen came saying downloading do not turn off target odin mode avb fail . i tried to flash it but odin was stuck at vendor.img for several hours. Then i quit odin and then a screen came saying that to recover from smart switch. Then i used a tool to fix the soft brick and now i am in the same downloading screen but this time saying error validating footer. i tried to flash again but am still stuck at vendor.img. i tried a different csc version and that stucks at system.img
PLEASE CAN SOMEONE HELP!!!!!!
I tried the pit method and on one laptop it gets stuck at system.img and on the other laptop it gets stuck at vendor
And i would also mention that when it gets stuck at vendor another red line in the top left appears saying custom binary system blocked by oem lock
I had asked someone in xda but there is no reply and a day has gone cant you help?
I've gone over things that could be possible through messages here , I would need to see the device in person which is not possible.
What windows are you running both computers? Usb port are not 3.0 ?
I think there is something wrong with the pit or vendor.img file
I doubt it , you tried from multiple sources
I'm also trusting everything I'm saying you did exactly. Sometimes people don't follow steps .
I would also like to mention that when it gets stuck i cross the odin app and then use the hijacker tool to fix the soft brick which is that a screen comes up saying to use smart switch application. After fixing the soft brick the screen saying downloading do not turn off target comes up
Yeah something went wrong , and that tool might of did something, I tried but it's something that now needs a person to look at .
Sunilkumar
