Establishing a connection between computer and my Edge
Abby Normal
88
I just brought home my new Edge.....
I want to move some ringtones onto it.
What is the right way to connect my phone to a windows computer ????
I can connect with a usb cable but that seems to only charge the battery...
There must be something i need to open or click on........
Can anyone save me from searching like crazy for the answer ???
Thanks in advance for any help given
Make sure you allow the mtp connection on your phone when you connect it to the computer.
Once that is done, you just drag and drop files as you wish.
Also keep smart switch very handy for backups and side sync is really ultimate, it's mirroring your screen on the pc/laptop and let's you do anything from there call msg etc basically use your phone from your laptop
Morphey1
