Everything is password dots...
I am glad I am not the only one with this issue! I thought I might have changed some settings and didnt know it. I also am using the stock keyboard and stock browser.
Glad I read this thread before I started digging through my phone for garbage that might've got installed.
Another glitch on the Google home, the voice input Mic is greyed out. I don't use my Voice Search widget. I open Google and use the Mic to search while at stop lights.
Just for the heads up I believe some inspire phones are having the same dottie problems . Does that mean that phone from the desire family ate having the issue? If so, will at&t also throw in a update to fix this annoying issue?
htc inspire
stock rom
PS this was on the stock bowser:confused:
This seemed to work for me, didn't reboot phone yet but this fixed it for now. Go to the browser settings and simply put for the homepage "www.google.com" then close the browser and reopen. Worked for me.
fixed
I think the problem is fixed now all you have to do is google Google and set the current version as your default. Fixed and when you open a knew page be sure to use the knew homepage not the old one because the old one still dots.
HuanNguyen
