Evo 3d working with Palm Touchstone Charger
In my mod, a bought the powermat receiver back for the EVO 4g. I removed the USB plug and soldered the wires from the touchstone coil to the USB pins 1 & 4. This USB plug is very low profile and does not stick out much at all. It is very easy to plug and unplug when using a straight USB plug. I do notice that my charging time is quite long. It must only be charging at 500mA. I downloaded the utility mentioned above, but not sure how to get it to collect data. How do I short pin 2 and 3 to get the full 1000mA? Another posting mentioned shorting the pins on the charger side?
1) Current Widget - https://market.android.com/details?id=com.manor.currentwidget - is a widget. It only works if a widget is added to a home screen: Menu -> Add -> Widget - Current Widget, then you can change a few settings, like how often to refresh, log into a text file, etc. Without changing any settings, you'll get a 1x1 widget showing the electric current in mA, refreshing every 60 seconds, with the manual refresh button on it. Note: not every phone reports electric current to the system. I personally tested Current Widget working on HTC EVO 4G, Samsung Epic 4G, Motorola Xoom WiFi, and not working on Motorola Droid Bionic. Alternatively, if you have a multimeter (and you should, if you do any electric circuitry soldering), you can measure electric current on the touchstone coil contacts or wires going to the microUSB plug.
2) Shorting means connecting wire or soldering together. Just put a little bit of filler metal (solder) between pins 2 and 3. This will give the phone a signal that it is not connected to a computer and so it can draw 1000mA, instead of 500mA, from pins 1 and 4.
3) Shorting pins on the charger side will have no effect here. (In fact, the wall charger already has pins 2 and 3 shorted.) The phone only "sees" the microUSB port (jack, plugged into it). In your current mod, the microUSB jack is only connected to the touchstone coil with pins 1 and 4. Pins 2 and 3 are open (not connected to anything or each other), which signals the phone that it is plugged into a computer data USB port, and it limits the electric current draw to 500mA and expects data exchange through pins 2 and 3.
Good luck!
I am thinking about doing this. Bought the Palm charger and cover for 7 bucks off amazon. However I dont want the usb port to be used. I was wondering if anybody soldered the wires straight into the USB pin on the motherboard.
There are a few of them done for other phones but nothing for the EVO 3D.
I can solder with no problem.. however I need to figure out where to do it.
Were you able to do it?
I am planning on doing this, but I need to find a place to solder the positive wire. I
byronsss
