Thanks for helping while i was gone glad you guys got it working ok
Anytime and thanks for the root fix......(I really needed that) allllll rooted and loving life again
This is supposed to work for 1.22.651.3 but OBVIOUSLY NOT!!! Haven't seen many success stories and I am currently sitting here with a unlocked bootloader and no root access!!!! What is taking so long for a root method that will work???
Hey could i still root my phone if i have this set up
Sent from my EVO using Android Central Forums
I think it's a bit generous to say that this method is "easy." A method (as yet to be found) that can do an in-place root would earn the classification of "easy," provided it's more or less menu driven.
Pi
This method causes the loss of all data (which, when restored, isn't always successful), requires unlocking the boot loader, and then uses a set of tools that were meant for an older ROM version. Although it appears to work, it's not "easy."
Joel
Yes just follow the procedure in the OP and you should be fine I have the same software as you![]()
Say gitit,,,,may want to add to the OP that antivirus and firewall software will block the install process.....that was the only thing i had to figure out when I was trying to install,,,,just a suggestion.....;-)
Otherwise this is a great method for those of us that either took the update or purchased late and got stuck with the update on the phone.
does this make your phone s-off?
do you know if gamecih needs s-off? thats pretty much why I want to root my phone, so I don't want it to go to waste.
