Evo 4G LTE 1.22.651.3 Root (EASY)
Never mind. I found it. Disabled firewall and antivirus. I am having problems tethering though. My phone and laptop won't find eachother.
I'm running windows 8. This is a brand new PC that I built and I installed Win8 because the release candidate is free and therefore I wouldn't have to buy another copy of windows 7. However, the HTC drivers do not work on windows 8 (it says drivers are not compatible with this operating system). Is there any way I could do this method on linux or something if I made a linux partition?
I'd appreciate any help or suggestions on this!
I could really use some help!!!! I'm new to rooting. I had my evo 4g lte rooted when it was the 1.13.. for some dumb reason i updated to the new 1.22.651.3 710rd.. and i can not get it to root . i've seen some people say u need s-off and if im reading it write some people say it doesnt matter. well with the program im trying to use now it unlock the bootloader does everthing and fails the root at the end...(RegawMOD).. I unzip the file and I can't find the file i need to put into my sd. and how do i put that onto my sd ? when my phone is conected its a diskdrive only... idk HELP!!!!!!! lol THANKS!
i figured it out ...each time i would extract the zip file it would show the file i needed but i found it . and i figured out how to send stuff to my phone . thanks anyways
Google search it. It's actually pretty easy. Someone posted the files needed for installation on a 64 bit machine. if you can't figure it out, PM me.
This method absolutely blows. Lost all my data and never got into recovery. This guy needs to find something better to do than to bring bogus rooting methods to a public forum. My two cents. Spare yourself and move on.
Unlocking your bootloader will essentially perform a factory wipe (lose all data). And I'm pretty sure an unlocked bootloader is required for hboot 1.12+ (or whenever the update happened). Besides, the instructions say in big red letters to back up since you'll lose your data. Might help to read the entire post before starting something like this.
Okay thanks now all i need to do is to find the rom that i like
Sent from my EVO using Android Central Forums
---------- Post Merged at 10:57 AM ---------- Previous Post was at 10:57 AM ----------
You can't be serious
Sent from my EVO using Tapatalk 2
HELP!!!
so my bootloader is already unlocked.
i'm updated to 1.22.651.3 710RD
but i lost my root.
is there any way to RE-ROOT WITHOUT ERASING EVERYTHING?
I CAN'T back up with titanium because my root is gone.
PLEASE HELP!!!
HELP!!!
but i lost my root.
PLEASE HELP!!!
A unlocked bootloader is not rooted . Install a custom recovery and either flash superuser zip or flash a rooted rom
could you please help me figure out how to do this?
i'm a super noob.
so any help would be majorly appreciated.
fyi my bootloader is unlocked and my phone is listed as "tampered"
thank you
i'm a super noob.
thank you
Go HERE this will do what you need just follow the instructions i think there is a video also
thanks benny3 the only worry i have is that i think this wipes all data and i still need to back up my stuff..
but because my root is gone i can't use titanium back up.
do you have a good suggestion for a non-root back up prog?
Shawtiee
