exchange calendar not syncing - anyone else?
I used Google Calendar Sync. I can see my Google Calendar on my PC through GMail, but it does not seem to be pushing to my phone. I set up the mobile settings for Google Calendar through my PC. I have manually synced using my PC and the web version of the calendar looks fine.
I edited a calendar entry just to see what would happen. I used my PC and the Google Calendar website. The edited entry was pushed to my phone and back to my Outlook, but none of the original calendar entries that I have in Outlook (and Google Calendar) are showing on my phone.
Sorry for the newbie questions, I just need this to work. I still need to figure out how to port over my Outlook contacts and have them sync automatically, too. But, alas, one thing at a time.
Thanks for all of your help.
I have this exact same problem and the same thing happens when I make a change too. UPDATE: I just fixed this. I disabled AutoSync. Then I unchecked all the sync options for my Google account. Then I manually sync'd the calendar. It updated all my missing appointments. Then I enabled AutoSync and the other options. Working for now at least.
is your login user name different from the email name ?
for example : I have seen this problem happening when you have
email : treef@company.com
login : tom
full name : Tom Reef
there is a workaround if this is it..
I'm having the same problem with one user and believe it may be that the login and email name are different....you say there is a "workaround" for this? (crossing fingers)
Thanks in advance.
Jayarealways
