Extended battery for Atrix 2?
scrondar
181
Does anyone know if such a thing can be had, or if the extended batteries for the 4G will work? Many thanks.
Well, $45 for an extra 125 mAh seems a bit steep. For that kind of $$ I'd probably go with the OEM one linked above, but thanks.
Available from the Motorola Store for $49.95. Stick with OEM from Moto...
Extra Capacity Battery and Door for ATRIX 2 - Compatibility - Motorola Mobility, Inc. USA
Let us know how it works out for you?
It works fine. Friend of mine has it. It's < 2800 mAh and it doesn't make the phone too much bigger.. The battery door is very secure, very. Recommended. It does make the phone quite a big heavier, though. Atrix 2 with that battery is easily 3x as heavy as my Skyrocket.
I never recommend anything but stock extended batteries, personally.
kctraci1
