Extra battery kit back in stock!
Looks like its out of stock again.
In the past I have bought much cheaper extra battery + charger on eBay. Are those not safe to use with Note 4?
I've heard of some overheating. I used to buy knock offs also but never had the same performance as OEM. I wouldn't buy this at $45, but you can't pass this up at $22.
I like using it because it saves the wear and tear of always plugging in your usb charger into the phone. You know those connectors get loose after the hundreds of times you plug and unplug it. I also love not having to worry about how much battery I have left.
Got mine today. Couple of notes - it does not come with a power source and cable, just the dock and charging station, and it does not appear to do quick charging (I am using my Note 4 power block & cable with it). The dock lacks the quick charging smarts that are in the phone.
williestringfield90
