Facebook Build 141046 in Notification bar?
i had the same problem i think it came from a email from a friend gmail that was hacked it tried downloading for hour and it did and i did go to down loads other and deleted it but a pop up came about a new facebook i did do it and my phone is ok today hope it helps
i am finally solved this problem...
thanks for read :
solution:
goto Setting - Applications - Manage Applications
choose tab -> ALL
Find the application -> Download manager
DO -> Clear Cache, clear data or force stop
and Finish
result :
Facebook buil notification bar missed.
:pgood luck:D
I have tried every thing suggested to rid my LG Lucid of this thing tono avail.
Why is it a problem if I just let it install? Is this a "beta" I might not want?
Sent from my DROID BIONIC using Android Central Forums
What is was is an update straight from Facebook, not from the play store so if u allow install of non-market sources then this allows the update to be pushed to ur device. It only installs over Wi-Fi , not mobile data, so until u turn on ur Wi-Fi or stop it its just going to sit there. On Android 4.x u should just be able to go in ur app drawer, select downloads, select it and press the little garbage can in the top right to delete it.
Go to you Download Manager, you'll find Facebook (build 141046). Check the box next to it and delete. It's the only way. I've tried and that works.
Just go to the downloads widget and open it and it will show recent down loads. Just press and hold the facebook build and it will give you tthe option to delete that download. Press delete and problem solved.
Same problem mine has been days.... I have a Verizon G'zOne , I have tried all the things listed. Reboot, Battery out, Stop all downloads, Uninstall facebook, reinsatll, nothing has worked. if anyone has any other ideas... i am up for it. HELP!!!
Go to download, look for this face book download within last 7 days segment,then ;) select the file and delete it... It will resolve the issue
I just hit the download button, checked the facebook build, (which showed "in process' for more than a week) and then the delete button.
All i had to do was cancel the notification! Duh!!! Bit its bern a great tutorial form. You guys are great!
You're a boss, worked like a champ. I know ALOT about my phone (original razr Ive had it 9 months! new record for me. Otterbox is the case to get!) and android in general, but i could not figure this out! No gonna lie it hurt my pride a bit being beat by a phone. :'(
Thanks again bro!
Yep , I had the same problem. And for a VERY long time I couldnt figure out how to get rid of it.
Samsung Galaxy S II .. I went to Downloads then clicked the tab "Other downloads" and checked the box and hit the delete trash can thingy and that got rid of it :) Phew
It was getting on my nerves!
pls help me to remove an error of "Facebook (build 1410146) " from upto 48 hours on my HTC Inspire 4G , i tried many times to on/off the phone and also remove battery n SD Card but still get this error and also uninstall the Facebook app but its not disappear on notification bar,,
pls help me anybody ...
OMG!! it worked!! :D thank you so much! I have also been trying to figure it out till just now! WiFi worked lol
Same phenomenon is happening on my Sony Xperia ICS.
Looks like uninstalling and reinstalling FB app doesnt help...:(
Gremlin69
