Fast Charging not working after Lollipop update?
Fast charge doesn't work on my Note 4 after lollipop.
The button is greyed out like the pic above.
Before LP I got a notice on the top bar that fast charge was activated upon pluggng in the phone, now I don't.
Exactly the same problem!! I twittered to Samsung about this issue but haven't heard back yet...
I'm having the same problem. And home v. car charger is not the issue. It is a direct result of the upgrade to Lollipop.
Also, apps seem to be running slower...or is that my imagination too?
I get fast charging in the car or on AC, the phone will charge 100% in about an hour and I'm on ATT lollipop.
I turned off fast charge. It does the battery no good at all. Reheating the battery at high temp, does the battery no good at all.
I only use fast charge. The N3 and S5 had fast charge, you just couldn't turn them off. My battery never gets hot when charging.
Is anyone getting the 'fast charging' notification when they plug theirs in? I used to get this notification before lollipop but now I realized it no longer appears
I get the same notification I always got in the pull down shade. Did you check the battery screen and make sure fast charging still has a check mark beside it?
mcheck
