Mike Dee
Ambassador
- May 14, 2014
- 23,452
- 319
- 83
By default the fast charging options are supposed to be enabled but it would be nice to know for sure.
I have a Ceramic model, but I assume that doesn't change to things.
I guess there is no setting on Verizon. I hope that doesn't mean it doesn't support. I have wireless chargers but 1 is normal charging and the other is only fast charge compatible with Pixel.
I just checked my settings . My Sprint phone does not have the fast wireless setting, either.
I have Verizon. You need to go to battery then click the 3 dots, then settings. Under this menu it will show the fast wireless charging option.
I have Verizon and only the wired setting. I also have an older Samsung wireless charger. I believe I remember that you don't see the wireless option until it is placed on an appropriate fast wireless charger.
Wireless charging will not show up until you place your phone on a wireless charger that will work with the phone. This is on Verizon phone
Please read earlier posts... Several have said it's not in the menu until you put it on a wireless charger that works. When you get the phone the only fast charging option in the menu is wired, that will change once you put it on a wireless charger. I don't know why they did that, but that's the way they did it.
I have Samsung wireless charger pad model EP-NG930 that says fast charge on it, the thing is when I tried to charge my S10 it's not fast charging.
and when I tried to go to settings I can't find the fast wireless charging toggle, my phone only have fast cable charging toggle.
that model only equipped w/ micro USB plug so I can't plug my type C cable on my wireless charger pad
what should I do ? pls reply
Where did you buy the charging pad? Apparently there are people selling fakes that look pretty close to the real thing.
Can check in settings>advanced feature>accessory
I already checked and there is no accessory options on my advanced feature, what should I do ?
