- Oct 1, 2013
- 4
- 0
- 0
I deleted download mode following a tutorial to fix boot. It booted up and now I get "Invalid Battery". I bought a new battery and replaced it, same error. I assume it something with the partitions. I have the correct image files but they won't flash and I can't use fastboot erase.
Screen right after fastboot boot:
[500] Fastboot mode started
[600] -- reset --
[610] -- portchange --
[710] fastboot: processing commands
fastboot erase aboot brings:
erasing 'aboot' ... on command prompt
and
[346290] fastboot: getvarartition-type:aboot
[346350] fastboot: erase:aboot
after those appear it just hangs like that
unplugging it after that command gives me:
FAILED (status read failed (Too many links))
finished. total time: 164.350s
on cmd
and
[514820] -- reset --
[514820] EP1/out FAIL nfo=40 p0=f90bao0
[514830] -- portchange --
[514840] usb_read(0) transaction failed
[514890] fastboot: oops!
[514940] fastboot: processing commands
trying to flash a partition has it tell me the file transferred but then it hangs
The computer definitely recognizes the LG G2 but all I can get into pre-boot is fastboot.
[600] -- reset --
and
on cmd
and
