Favorite LG v40 Cases
It isn't that much bigger really. Obviously the sides are more reinforced. I think it's the same case with reinforced sides. It adds a little thickness on the edges but not a ton.
Everyone seems to like the slim cases. Guess I'm the oddball then.
I put a LoveMei Powerful case on mine.
Beefy and heavy but built like a tank.
I'm thinking of getting that one. Currently testing a battery case, but I'm not really feeling it. This Ringke case would look good with a Skinit skin.
Great cases. The only issue is it's not real friendly with tempered glass protectors. You can't use an edge to edge or it will bubble it causing decreased sensitivity. Some of the slight smaller tapered glass protectors work but if you drop the phone it pops off the protector. I have a few cases and only this one and the cheaper version of this with out reinforced edges does it. I actually put a film type protector on because I am not spending $7 to $8 every few weeks to replace tempered glass even though it's my preference. I see carbon fiber clear screen protectors but never tried one.
Fortunately for me, I don't use screen protectors. I got this case last week and I like it. The way it's shaped feels like it locks it in hand. The only thing I don't like is that it's hard to tell the volume and assistant buttons apart. The space between them should have been recessed to leave a gap.
DonJrPlayz1234
