"Files" causing major battery drain
danlayman
15
On my Droid Bionic running ICS, my extended battery is struggling to make it 12 hours on a full chaege with light to moderate use. The battery analysis shows "Files" consuming at least 60% of the battery. Any suggestions as to why or how to stop it? Thanks in advance.
Weird. Files does not even register on my usage... it does this even after a restart with battery pull?
Sent from my DROID BIONIC using Android Central Forums
I force stopped the application. Recharging now. The amount of CPU time wasn't super high but it clearly was intensively using battery resources while active. I've deleted several tuning and back-up applications. I will recharge overnight and see what happens.
hubolt
