[FINAL][ENDOFLIFE][ROM][ZVD] Joylicious, JoyOS, v1.0.3d - 8/25!
Hey the virgin mobile stuff in status bar is in Eri.xml in frameworkres.apk
Sent from my LS670 using Tapatalk 2
Re: PLEASE HELP ME!![ROM][ZVD] Joylicious, JoyOS, v1.0.3d - 8/25!
Are you freaking kidding me?! Seriously? How did you find this out? OH MY GOD. You just saved me from that part of my confusion.
I love you. LOL
I love you. LOL
Yes you can try pulling a eri .XML from a sprint rom but pull from a cm7 rom
Sent from my LG-LS670 using Tapatalk 2
Hey Patrick I can do the frameworks Eri.XML job and upload the modded one if you like:D
how would one go about installing status bar icons on this rom?
Sent from my LS670 using Android Central Forums
Patrick, im trying to install status bar icons on this rom. how do i do that?
Custom status Bar icons. im trying to install the with Rom Toolbox pro with no luck. is this rom odexed?
The custom icon installer in rom toolbox has never worked for me on any of my phones(opti s, evo 4g, viper lte, marquee, x2, or s3) both stock rooted and custom.
Sent from my LG-LS840 using Android Central Forums
Hello all,
while running this rom, it seems that any widget which calls up the alarm service doesn't work. For example, i use the Retro Clock widget to periodically set alarms. I noticed similar behavior to with the Digital Clock Widget. I assume this has something to do w/ the Clock app being renamed to the Joy Clock app, and these widgets are looking to call the Clock app. Anyone know how this could be rigged up so the JoyClock app is simply called Clock so other apps can use its service?
Thanks,
-- bkn
Re: [WIP][ROM][ZVD] Joylicious, Port of JoyOS + CM7, Alpha0
Guys.. I am sad to announce that I have to end my development for this ROM. I've got to focus on my school work and I am not having much time to develop it anymore. The links should still be working. I am going to leave links alone..
You may flash this if you want as long as it is flashed on ZVD.
:'( I loved this ROM...
Moderators, if you want, you can lock this thread.
tsmtoolpro
