Fingerprint sensor ultra slow after Android P
alexmartins
Active member
Mar 10, 2017
26
Hi,
Anyone stuck with an ultra slow fingerprint sensor in a Pixel 2 XL after upgrading to Android P Beta 2?
Thanks in advance.
I notice it as well. I assume it is a bug that they will fix. I did submit a feedback though just to ensure they know.
yeah, my XL takes at least a second or two to awaken after hitting the fps. Not a tremendous issue, but definitely noticeable
Ditto , so far the only issue I've experienced.... but the performance and battery life make up for it.
I'm sure they will correct with the next update.
How slow are we talking? Mine is almost instantaneous. It always bugs me that everyone experiences different issues with updates or Betas. Makes me think it's somewhat related to what else is installed on the phone, however in the case of the fingerprint issue that doesn't make sense.
Very slow. One or two seconds after touching the sensor.
yeah I've been noticing this one my pixel 2 XL since swapping to P beta. it's a small delay for me, but definitely noticible.
Fingerprint, vibrate, 2 seconds later screen lights up.
Yep same here but can hack it til either the next P update or til the full blown version is ready for release.
opegamani
