Firmware question
So so far we think/feel it: Possibly does something to the camera, supposedly increases screen responsiveness, and locks the bootloader? I guess I'll go ahead and install it if it comes up for me next time I turn my Prime on.
I just done the firmware update, restarted ok. then it shows there is another camera update and the ecc pad update, downloading the ecc pad update, now the touch screen is not responding. I could only press the power or volume button, nothing else. what can I do?
thanks.
I did the update...google+ constantly force closes now, without me ever even touching the app. Though when I do try to launch it, it launches and immediately does force close. Had absolutely no problem before the firmware update, and I've changed absolutely nothing in-between, all variables are the same, except for the new firmware update. Disappointed. :-(
I'm restarting it now, after giving up when updating it in the market didn't fix it. I'm hoping for the best. No other apps are doing it...really strange. Also strange it's only happened to me, but...what can ya do.
edit: Finally got it working correctly again after clearing its data/cache in the settings. Relogged into Google+ and everything is back to normal. Weird how the firmware update messed something up inside that specific application, but, glad it was an easy fix.
Besides that one small issue, switching between screens and transitions are much quicker and fluid, and Asus released a popup after the update that says if we are using the large icon set, we might need to revert to the smaller icons again. I did, as I was using the larger icons. These look soooo tiny!
Reactions: rew001
Thanks for the edit. Will try that this evening, as I have the same issue after the .33 update.
No problem at all! Hope you get it working again, too. Let me know if you have any questions.
Andacar
