"Firmware upgrade encountered an issue. Please select recovery mode in Kies & try again."
Raithed
3
Hi all, I have an S4 that is rooted, and I was trying to unroot it, after Odin failed twice, my phone got stuck in the error screen. Currently, it is stuck in Odin mode:
Product Name: SGH-M919
Current Binary: Samsung Official
System Status: Official
KNOX Kernel Lock: 0x0
KNOX Warranty Void: 0x1
CSB-CONFIG-LSB: 0X30
Write Protection: enable
eMMC BURST mode: enable
The phone basically is disconnected from the USB, my PC does not see it anymore. I downloaded Kies and it does not work (USB cannot be detected). I also tried holding down the Volume Up, Home and Power buttons - no good, it goes back to the screen.
Volume Down, Home and Power buttons.
I downloaded my firmware from Androidrootz (4.4.2 - M919UVUFNB4)
Any help is greatly appreciated.
EDIT - Thank you for reading, I have fixed the issue by using another machine
Re: "Firmware upgrade encountered an issue. Please select recovery mode in Kies & try again."
Hi! I just came upon your post, and I am stuck exactly at the same place you were, any insight on how you solved your problem would be very appreciated, I would have liked to post a link to my original post on this forum but apparently I can't. If you go look under my posts, you'll see it
"HELP ! Samsung Note II - Stuck with Firmware upgrade encountered an issue. Please select recovery. What can I do?"
Thanks !
Try to use a different machine if ODIN isn't working for you.
If you are on official firmware samsung you can use allsamsung recovery download the file go to Odin press pda locate the file then start I had the same problem with you after trying to downgrade my s4 mini I unbrick my s4 with this file very good file
dkpiper
