Damn. This is a miracle. //uploads.tapatalk-cdn.com/20190824/8aaebccec5b748ddfcf4bc77a3e7997c.jpg
Honestly, the battery life really really stinks. With my P30P i could use Google Maps for almost an hour and the battery would've dropped around 5%-8%.but with the Note 10+,it would drop 15%-20%...yeah i know let it be for a week so it could learn my patterns and stuff. But i dont recall doing that on my P30P...
Wuuuh? Is that 5 to 8% an hour with the display on for the P30? That works out to 15 to 20 hours screen time with a resource heavy app and using power draining radios too. If that is with the screen on, respectfully seems a "tad" overstated. Even off it seems thrifty.
What i meant was. While using Google Maps for an hour. The P30P drains only 5 to 8 percent. Whereas the Note 10+ drains 15 to 20 percent.
He got you, he's just saying that if having the screen on for an hour using a heavy battery draining app only drains the phone 5 to 8%, that would mean the phone is capable of providing 15-20 hours of SOT, which doesn't sound right.
Keep in mind too, your best battery performance might not hit until after you've broken in the battery with charging and depleting multiple times, as well as your phone settling with having all its updates done, settings configured how you like it, and no longer touching it nonstop because it's the shiny new toy
