williams448
- Dec 1, 2012
- 787
- 70
- 28
When you swipe down the quick settings panel, tap the pen icon and you can revert to the old swipe down way. You can also can also change it to where the notification panel is on the right. That's what I did because when using one handed within an app and I received a notification, it was difficult to swipe down from top left corner.Has anyone figured out how to get notifications on the drop down menu like previous versions of Android? It seems like I have to touch the phone on the left side of the camera in order to get a separate status bar for notifications
You can also swipe right and left after you've swipe down from either side. For example if you swipe down from the right for the quick settings panel, you can swipe right and the notification panel will show. Instead of swiping down from one corner, swiping back up just to swipe down from the other corner.
This was definitely the biggest OneUI7 change that I'm having to get used to, but after using it for a few days it's getting to be less of a nuisance.
