flash player not working on new Galaxy S3
Wicked I got Flash working fine now with Firefox ... BUT ... everytime I go to a site with flash on it i have to keep activating flash plugin to see flsh content ... anyone know how to make it stay on all the time? ...
cheers,
Gem
I had the same problem go to adobe .com.Then type in search bar Archives. A page will come up and at the top click on archived flash player versios. Then scroll down and look for android 4.0 click on 11.1.115.17 version. This will automatically dowload .once downloaded slide down your task bar and click install. It should work no problem make sure you see flashplayer icon in your app page.also go in to internet settings in your browser and click advanced. From their make sure you have plug-ins turned on
Go to adobe .com type archives then click on archived flash player versions. Then scroll down and find android 4.0 click on 11.1.115.17 version and it will download.
Just had the update to 4.1.1 on the S3 and I am not longer able to get flash player working on FireFox, Dolphin or Chrome
You have to root to have flash with JB. Root your phone (caution: please read a guide for your carrier so you do not break your phone) then download and install the apk.
http://forum.xda-developers.com/showthread.php?t=1855180
Sent from my Sprint S3 using AC forums
Not true. Here is flash player. Download it, go into downloads and install. You have to allow installation of non market apps. It's in settings. Don't root your perfectly AWESOME S3 if u don't know what your doing. www.2shared.com/file/BiffvXev/adobeflashplayer-1_Android4.html
O_o WISHING I HAD WAITED AND GOT THE NOTE 2, ANYONE WANNA TRADE? o>_
I download flash player 11 just go to setting 》security 》 unknown source and put the check on the square after that go to the market and download flash player and ready
Setting))) security))) unknown source click there and them go to the market and download flash player really easy
Ey brother just go to setting security unknown source click there and then go to play store and download flash player
Phone: Galaxy S3 running Android 4.1
PROBLEM: No flash player/ downloaded flash player not working in multiple browsers
SOLUTION: somewhere in this forum someone posted a link to the archived version of flash player 11 follow their directions download it. Dolphin browser has a block on flash enabling. If you go into the settings and try to turn it on you will get a message somewhere along the lines of it not being compatible and crashing. Take a look if you dont believe me. What worked for me, dare I say it *cues dramatic music* THE STOCK INTERNET APP!!! YUCK I know but it works.
Hope this helps.
I've been trying to down load flash player it down loaded ok, and I've allowed unknown sources. However when I try to open flash player it says setting but page won't open?
I ended up downloading an app called video catcher and when you that program it tells you that you don't have adobe flash player installed and asks you if you want to install it. Click OK. Then it downloads flash player with nooooooo problems.
alexajamez
