Flash support in 4.1+
How do i install this apk ?
Download to your device. When its done click on it from the drop down and you should get the option to install. Will need to go into setting to allow side loading of apk files.
I installed flash from the link in this forum and tried using dolphin HD it worked but it was really flaky and caused the browser to crash when I tried to go full screen with the video
thanks it worked :D
Unfortunately I'm having the same problem with the flash 11.1 apk. Has anyone else found a more stable combination of a specific third party browser / flash apk version that doesn't crash when trying to go into full screen while viewing a video?
Thanks :cool:
I must be out of the loop...I have not encountered a web site that needed flash since 2008(I mean one I cared about). The less we use this technology the sooner they will have to encode to html5. Is porn the only thing folks use this for?
Unfortunately the hbo go app is not updated for 4.1 yet so a flash based browser appears to be the only option.
mathewsjamie138
