Flip Case Users
After a day without it I put the case back on. I missed it do much.
Sent from my Samsung Galaxy Note II using Tapatalk 2.
Lmao!
Sent from Note 2 via Tapatalk
I don't know, I like it but then I don't. The convenience is a positive but the flip case does make using the phone for the internet and texting a bit more annoying. It's a double edged sword sort of speak and I don't know which way I'm going to go in the end.
I find that the camera is not an issue because of voice commands. Flip it open/hold camera and say "shoot". Makes it easy for me to deal with. If i actually had to take one hand off of the device to hit a button to take a picture then the case would get in the way.
Sent from my SPH-L900 using Tapatalk 2
I finally messed around with this and it sure makes the camera easy to use. Thank you.
It's a beautiful thing right? Works great also, ,no glitches. Always have 2 hands on the device while you take a picture. :thumbup:
Note 2, it's true, ,size is everything!
Yes, it solves my main and only real complaint. I am nt a big picture taker but when I want the take one I can. I had to enable S Voice since I never did it beforehand.
S voice is great . go into settings and set up commands for the other options like when i light the screen, without even unlocking the phone i just say " open camera and the camera opens. .another way to open camera is turn on the option to light screen and without unlocking put your thumb on the screen and turn phone landscape and the camera will open. You can answer phone by just saying "answer" or what ever command you choose.
I have the official Samsung flip cover, and it works just fine in the iBolt dock
Thanks Mike-Mike. That ibolt dock seems more like a clamp, as opposed to say the Samsung OEB dock. Some of the Galaxy Note (2) docks merely have a pin that connects to the phone while it is stays in an upright, vertical position. So, I am specifically wondering how folks with flip covers might still be able to use a dock like this one:
Samsung Galaxy Universal Multimedia Desktop Dock
Is it doable? Does one keep the front cover open like a book? I figure one certainly cannot fold the front cover back and insert the phone into such a dock.
thx
thx
I bought this one, should be here tomorrow. It looks like with the samsung flip it will work. Also if you blow up this picture there seems to be a slim case on this note 2.
thx
I have that exact dock and the Samsung OEM Flip Cover and it works just fine with the dock. You can leave the cover open like a book or you can close it. When close, it "hangs" or sits a little bit crooked, or at least doesn't close quite all the way, but's not that noticeable. Here are a couple of pics.
I had that RND charger for my Galaxy S2 and loved it. Not sure if the Flip Cover will fit into it, though, unless they've given them more wiggle room than they used to have. I know they make them with a removable insert around the charging plug and inner sides now so that you have more clearance when you have a thin case on it. Just wasn't sure if there was enough for the flip cover.
Always did love that design, though. Very secure and looks nice. Are you using the charger that came with it or a 2 mAh charger like the one that came with the GN2?
EDIT: In fact, I was going to get that very charger if I didn't have the 50% discount coupon from Samsung for registering my GN2. :cool:
Thanks bigoldthor and zmann. Great info, and pix. I also have the RND dock, btw, and it does work with a thin case. The Samsung OEM dock has a little more room. So, given what bigoldthor showed, I am going to get the Spigen case, which is one of their thinner flips, and I think I will be fine. Thanks again.
Regarding chargers, I only use either the stock 2.1A or a 3rd party 2amp. I took that measly 0.7A that came with the RND and through it in the "charger drawer." I have a rocketfish that is rated 2.0A and found some OEM Samsung chargers on Ebay. However, for the Samsung OEM dock, I use the original Samsung OEM charger that came in the box with my GN2.
O
the way the samsung cover is designed,, I am pretty sure,, could be wrong,, that at the very least it will work with flip cover open. I will report as soon as it arrives today. What has me not worried is the pic I posted, that phone is in a case. To be continued :D
Charlotte Breece
