For what are the 2 blue wires of the "Samsung Note Pro P900"-Battery and where to solder them?
  • Start date Start date
A
Android Central Question
Hello
For some reason i cant login (created account...confirmed email...login works...but when I enter forums-area, i get logged out again and cant answer or PM.
I wanted to ask the user "Beut" in the thread
"https://forums.androidcentral.com/samsung-galaxy-note-pro-12-2/679510-galaxy-note-pro-12-2-black-screen-wont-turn-no-activity-no-charging-icon.html"
for what the 2 blue wires are and where they need to get soldered.
For nothing (so not connected to bord-electronic)?
Or gets one blue to the red wires and the other to the blue wires?
Or maybe somwhere else?
Thanks a lot.
BR
Edi
Re: For what are the 2 blue wires of the "Samsung Note Pro P900"-Battery and where to solder them?
Plug the connector in. Each wire goes to that pin on the other side of the socket. (Note: I don't recommend doing this - at the very most, remove the pins from the connector one at a time and clean the top part [where the brass pin in the next-to-last picture sits on it], then put it back into the connector. You'll need the Molex tool of the right size to remove and replace the pins.)
Usually, if the soldered connections on the motherboard are good, just unplugging and plugging back in a few times will clean the connector well enough to work. (If there's a crack in one of the soldered connections, unplug the plug and heat the solder enough to make it flow. Just enough, no more. It just has to reflow around the pin.)
Marabishi
