Fozen in CMR
@dmmarck, if i buy Franco's app will it give me the option which kernel i want to flash or will it automatically flash his most recent kernal. i am new to flashing kernels so i want to make sure i dont screw up anything
It will always give you the option to download before you do. I posted a picture of the GPU MHz screen in the AOKP thread about a half an hour ago.
You download the app, and you have the option to auto-flash or download the kernel's .zip. If you choose the latter, you can simply reboot into recovery and flash it like you would anything else.
Reactions: DB12088
is there a particular kernel that you would recommend, i am currently running AOKP b38
is there a particular kernel that you would reccomend, i am currently running AOKP b38
I'd start with his latest milestone/stable--Milestone 4, 384 MHz GPU. Use the default settings for a day then play around with different governors to see if it's better/worse than that testing day.
Reactions: DB12088
I bought it today, you have the option with 2 selections, download the stable version (m4) or his nightly r180 and can choose what CPU speed you want.
you can either download or have it flash for you.
I started with m4 and than went to the 180 @ 512 with going back and forth with dmmarck.
Reactions: DB12088
thanks guys i know what i will be doing tonight i will repost after i dl the app and flash the kernel
Hey dmmarck-
was able to answer someones question thanks to all of your help today! I fell good. glad to help someone else. :)
Xanth-
Reactions: dmmarck
Hey dmmarck-
Xanth-
No problem. It's a bit cliche, but Android = community. When that goes to hell then we're nothing but a bunch of geeks with a touchscreen mobile device ;).
i bought the app and flashed M4, i will give a day or two to see how it does and then may move onto the nightly, thanks again guys for all the great info
Reactions: dmmarck
I bought the app and it seems to be working well with Liquid1.4. I might try AOKP out soon, but I heard that Liquid was pretty stable - so far so good, save for a few things here and there with customization options.
As for the Franco app, it is awesome. I love the color options: NO MORE GRADIENT LINES. I also set the gamma to 1.2 and I like it a lot - colors a bit punchier, albeit darker.
I was on 180 for half the day, but mabye because I was on it a lot, the battery life was considerably worse than when I was stock. I switched over to the Milestone 4, lowered my screen brightness, and changed the governor to conservative. The phone was flying on 180 lol.
Reactions: dmmarck
karhubet
