Froyo Questions
You can upgrade to 2.2 as your mileage may vary... then if it's not what you like, downgrade.
No way. I definitely want it. I just can't have it without rooting since I have the AT&T 3G Nexus One.
YES! I use a Jabra BT530 and just tried to voice dial and it worked. I pressed and held the action button on my headset and a dialog window popped up on my Nexus One without me touching it. It showed some examples of what to say and I said "Call X" and it dialed automatically.
What happens if it doesn't understand you, or needs to "confirm" what you said? Does it prompt you via BT? or does it work like the "speaker phone voice dialer" and prompt you on screen?
Are calendar invites (.ICS files) handled in the "inbox"? or do you still have to navigate to that time/date on the calendar to accept/decline/tentative? i.e. is Issue 1257 fixed?
Ahhhh.... gotcha. I didn't root for the longest (when I first got it) and finally said "the heck with it"
2. Did the trackball get multicolor notifications?
Yes. It's application dependent and up to the developer to use it in their app. You can test this with AK Notepad by creating a note, then select which color you want for the trackball when you set reminder for that note. Whether or not Google implements it into their own apps like Gmail, Talk and Voice remains to be seen.
Adekanmbi
