froze and crashed, should i be worried
Does anyone know if staples will let someone take a tablet back a second time if i were to get the same problem? Ps: could you guys do me a huge favor? Turn your brightness to maximum and tap the multitasking button and check your corners and tell me if u have any light bleed at all. This would really help.
Normally I keep my brightness below the A of the word automatic in the settings, however I did as you requested and went to the darkest room in the house and saw no light bleed.
As for staples return policy.... If it is a defective product, then as long as they sell you one that is defective you should be able to return it. Though I wouldn't be surprised if after a certain number of returns they made you ? test it ? before leaving the store. Best to ask then store manager yourself.
I'm getting tired of mine restarting. I'm rooted' which worries me that that may be causing it. I've turned off location services' yet it still reboots at least twice a day.
I know this is unrelated but i thought i should mention. The Play store is having a huge game sale. I got Need For Speed for $1, Chaos Rings for 3.99 and GTA III for $1 you might have to look for them cause they keep popping in and out of the sale section.
OK I just got my replacement. It also has light bleed. Not nearly as bad though. Doesn't really leak into the picture much, just towards the very outer edge. The whole tablet doesn't heat up as much as the outer tablet. There Is some more battery drain than the other one but its more consistent and I haven't conditioned the battery yet. Whole tablet seems zippyer with minimal heat. I'm hoping to get 8 hours out of this at half brightness after condition. Whole screen is like 10 or more percent brighter. Anybody know why media server uses 57% battery?
I've had mine reboot 2 times in the month *almost* I've had it. My uptime is currently at 194+ hours.
I typically use it for mostly web browsing and YouTube (I'm on it now) about 4 hours daily. I have all location services on. I only use chrome for browsing, matter of fact its the only browser I have installed.
gurusdex
