G3 Best (& Affordable) Screen Protectors, and Cases
I used this screen protector. Easiest ever to put on. Awesome very satisfied
iCarez® for LG G3 [Thinnest Tempered Glass] Highest Quality Premium Anti-Scratch Bubble-free Reduce Fingerprint No Rainbow Washable Screen Protector Easy Install Product with Lifetime Replacement Warranty [1-Pack,0.2mm] - Retail Packaging 2014
I'm now looking for another screen protector because the Spigen Crystal clear ones that I bought are HORRIBLE!! Smudges incredibly easy unlike other cheaper screens I've had in the past. The iCarez you bought I like because its THIN (.2mm) BUT the top of the screen on the left hand side doesn't cover the sensors unlike the Spigen one. The Spigen glass does but is quite pricey so I'm currently ordering a few cheap ones hoping I get a winner out of one of them, lol!
I just bought that same screen protector she did. I also got a spigen (all black) slim case coming as well.
Nice! Let us know how you like it! Also, let me know if you think the unprotected part will get dinged/scratched up or not. Thats my main concern about it. Otherwise, I may pick it up since its not too pricey.
I really don't think it is an issue just my opinion. I think you would be happy with this screen protector
I'll more than likely pick it up if I'm unhappy with these regular screen protectors.
Do you have the link?
I almost got that one. It's .33 though and wont work right with a circle case. I plan on getting that with qi charging as soon as it's available and .2 should work as it's no thicker than a standard screen protector.
I just ordered this :Skinomi Tech Glass - LG G3 Screen Protector
I've used the Skinomi TechSkin for over 2 years and love it. When I had to get a warranty replacement phone, I called Skinomi and they sent me a free (I paid S&H) replacement. I can't say enough good about the service I've received, and the skin itself. This will be my first time getting the TechGlass, but I have confidence in the company, so expect no problems. I'm just awaiting my order & I can report back how it is. I just wanted to add another option out there than the couple I've seen.
I'm also looking for a good slim case that will easily fit into a pouch.
Edited to add: I just saw that you have the Otterbox Symmetry. How is that? does it add much bulk?
(Thx in advance)
Why wouldn't it work properly with the quick case if it is .33?
From My LG G3
From My LG G3
The circle cases have an edge around the lip that catches the slightly raised edge of the phone so it doesn't slide all over the place. The .33 protectors raise the lip too much. So basically your cover of the case won't sit flush and moves around.
Yes.
I had the Quick window case for my G2 and a 9H .30 glass SP and the cover didn't lay flat. It would slide up and down...not much though...but it hindered the earpiece when talking and the LED light would get covered up. I ended up taking it off and buying the .2 SP (the one you just showed) and that fixed the problem. Now that I have G3, I got the same .2 SP.
I wish LG would hurry the flip up with qi charging cases or backs....
arpitatiwari0
