G7 Power Texts and Bluetooth
this_is_nascar
780
I'm coming from a G6 which had Moto voice capability, so my texts could be heard and read over BT.
Now that the G7 Power took away that ability, how am I supposed to know I got a text while connected to BT?
It won't audible alert over the BT or the phone, however, phone calls are working just fine.
I'm using the standard Android Messages app.
Can you use the Google Assistant command, "Hey Google, show me my last messages"?
Hmm, the unlock issue.:-\ Strange, because on my Pixel 3 XL, I can use that command and it will work without having to unlock my phone first. You have Voice Match turned on, right?
Open the Play Store app, go to the Google app's page, and scroll down to the Beta section. If you have the option, select Join Beta, then wait for it to update.
jesper76
