Galaxy Gear Fit (Home Screen Weather)
Problacklist
5
I have the Galaxy Gear Fit Paired with Galaxy Note 3. if I select the Weather Clock Home screen it displays (Tap here to use location info on mobile device) ive tried everything but no luck maybe im missing something. how can i fix this problem
You have to confirm it on your phone when it says tap here. You also need to have the stock Samsung weather widget on your phone. So if you're running a custom launcher or anything it won't work. Select the box to use your current location. The screen on your phone will look like this-
kali-arm64
