Galaxy Nexus Screenshots: Share Them Here!
Any way to find the glowing "X" that shows at boor? I can't get a crisp image anywhere...
I assume you're talking about this?
I've uploaded the entire boot animation for you, simply download it and open with WinZip or similar. You'll find every frame of the boot animation in the folders labeled 'part0', 'part1', and 'part2'. It's not a live wallpaper of course, but you can pull out one of the still frames and use it with a black background.
echelonandroid.com/JellyBeanBootAnimation.zip
Please quote this when you reply and let me know you've downloaded it; I'm going to remove the archive afterward.
Edit: also, you can take a screenshot while the device is booting up. Set the phone to auto-brightness and restart it. When it is booting up and you see it adjust the screen to the correct auto-brightness level, you can then take a screenshot with the power and volume buttons.
In the mood for some Nexusy goodness.
Sent from the red headed stepchild of the Nexii.
there was a guy at work today talking about December 21st and the world ending
So i figured I can play along :p
Back to simple
That is simple! I bet the black helps with battery also.
dmflowsjalallodhi
