Galaxy note 10.1 2014 boot loop Samsung wont replace
Funny story...
So Kitkat has been released, for the TGY country code.. Yay!
P605ZSUCNE3_P605OZSCNE3_P605ZSUCNE1_HOME.tar
Is the md5 file to be put into the AP slot of Odin 3.09, for my tablet.
I was excited thinking this would address the issue.
Prior to flashing the ROM I factory reset from within the settings, then I went into the recovery boot meny and there I wiped the cache and did a factory reset once more.
Then I proceeded to setup and sign into my Google account, after flashing the ROM.
Naturally the tablet went ahead and started downloading and installing apps and updates from Google Play.
I was happy to see that it was progressing along swimmingly.
The screen dimmed down and then shutdown after period of inactivity (while downloading and installing apps in the background).
Occasionally, I'd click the home button to see tat everything was going as it ought.
I then noticed the screen turned black somewhat suddenly, without dimming first.
I thought little of it.But I went to check by pressing the home button... I figured maybe there's a little lag or the tablet is too busy installing, so I clicked the power button. Nothing; no response.
Then I held the power button for ten seconds+. That got it to reboot.
But now the tablet is just reboots at random intervals.
Now I don't know what to do. I'm afraid of taking it to the Samsung shop because they're probably going to do me like they did with the OP: trigger my Knox security and then void my warranty, even though I never even rooted the device.
wobblefix
