Galaxy Note 10.1: How to exit Factory Mode into UserMode
Re: How to exit Factory Mode into UserMode
I'm rooted, running adb as SU, and getting "Read-Only file system"
Absolutely did the trick. One thing that should be emphasized though is to use SU you have to have root...elementary but the ROM I was using didn't have it and I got access denied when typing the commands
@inflock, thanks. Your solution helped me get rid of Factory mode. However I think this mode reset my IMEI :(
To anyone who can help,
I was on Stock rooted 4.4.2 (international Note 2) when this Factory Mode thing happened. I have absolutely no clue why this happened in the first place!
I believe because of this my IMEI was reset to 004999010640000/01. I tried flashing a new ROM via TWRP. It did not help. I tried a few modems for this ROM (Dr. Ketan ND3 for Android 4.4.2). This also did not work.
I tried looking up this IMEI issue in XDA. Nothing conclusive there or on Google search either. I am hoping folks can suggest alternates. Will re-flashing an older ROM (via ODIN) resolve my issues? Please let me know other alternates.
the command efs/FactoryApp/keystr is about to removing .. no directory found mean you already did. so nothing to worry just complete the whole commands . it works like charm .
Here is the exact solution for this problem which i have recently had!
You have to root your phone and install Terminal Emulator from Google Play.
Open terminal emulator and type as ;
su
rm /efs/FactoryApp/keystr
rm /efs/FactoryApp/factorymode
echo -n ON >> /efs/FactoryApp/keystr
echo -n ON >> /efs/FactoryApp/factorymode
chown 1000.1000 /efs/FactoryApp/keystr
chown 1000.1000 /efs/FactoryApp/factorymode
chmod 0744 /efs/FactoryApp/keystr
chmod 0744 /efs/FactoryApp/factorymode
reboot
You now should not see the that message anymore. Its because of an EFS corruption. ( Thanks to yesilcin*com) for exact solution.
Hope it helps!!!
Thank you mate .
its work like charm ..amazing effort .
I tried using the method you suggested but it failed. I'm sorry I am not familiar with coding but I did carefully followed everything you said. when I entered reboot it was denied. What should I do? help please :(
these commands didn't work for me please help:'(
I need help
Heeeeeeeelp I need to turn off the factory mode without the root please any help samsung galaxy s3
hardva
