Galaxy Note 3 (Canada) Missing shortcut for mobile data in Notification Panel
kenali
Hi everyone,
Got my note 3 about a week, I noticed that in notification panel page I can't find the mobile data shortcut icon available, is it just mine or all Canadian user having the same issue?
Have the Same issue I just downloaded a mobile data Widget from the play store..
Sent from my SM-N900W8 using AC Forums mobile app
I noticed that too as soon as I got my Note 3. Maybe it's a Rogers modification so nobody calls up tech support saying: "My phone's broke. I don't have Internet when I'm not on Wi-Fi."
Sent from my SM-N900W8 using Tapatalk
Still stupid tho... Sometimes you just wanna turn it off... Like I do when signal is weak and I keep switching from LTE to 4G
I used to use this free app to turn data on off, you just create a widget with it on your home screen https://forums.androidcentral.com/e...id=it.miabit.android.dataonoff&token=wA7VExuj
but recently I have found an awesome app that turns off data when your screen is off and than depending on the intervals that you set will periodically turn on data just so your apps can sync, so that you dont miss any notifications like whatsapp,facebook... https://forums.androidcentral.com/e...id=com.falsite.ggovernor&hl=en&token=rOHapU5T
liquidsnake757
