Galaxy Note 3 - Case & Covers Thread
Re: Note 3 Case Thread.
Sure.
Sent from my SM-N900P using Tapatalk 4
Sure.
Is that all one piece? I have not been to impressed with Body Glove cases but I like the way the feel but are pretty bulky compared to a tpu case.
How much did it set you back?
Sent from my XT926 Vanquish
Just got email from Amazon,, my black speigen case will be here on Thursday.
THE BEAST,,NOTE 3. SIZE IS EVERYTHING!!!
My new case from sprint.
I got the same one.... A bit pricey but it's well worth it..
Sent from my SAMSUNG-SM-N900A using AC Forums mobile app
I ordered leather s view case off of eBay for 10 bucks
Sent from my SAMSUNG-SM-N900A using Tapatalk 4
My ideal case would be a flip case with a full clear view cover and clasp. Made of good quality of course. Any ideas or suggestions?
Sent from my SM-P600 using Tapatalk now Free
Does anyone know how good/bad the Spigen cases protect a phone upon dropping? I have never owned one and wanted some thoughts before I get my Note 3.
The Slim Armor on my iPhone 5 has done a good job. I've dropped it twice, both times onto concrete, both times from a height of about my waist. And one of those times making it worse by doing the juggle trick which only made it spin down even faster. No damage to phone in either situation.
Then again, not sure how much of that is the case and just luck.
I doubt the Neo will provide as much protection as the Slim, but the Slim scratches VERY easily.
I recieved mine yesterday as well. Fits nicely but the only thing I noticed was the volume and power buttons are a little wobbly. Are they the same on yours too?
The volume rockers on mine are a little wobbly, power button is solid though. I removed the case and reinstalled and now my IR blaster works fine. Must not have lined up perfectly when I installed it initially.
It does seem that the Spigen Neo Hybrid case needs a little bit to settle in with the Note 3. Mine was flush after about a day or two. Maybe it just needed some pocket time, haha.
Update to Swiper connection: The new Gray GoPayment swiper will work with the Spigen Neo Hybrid case if you remove enough rubber along the bottom to allow the swiper connection to go a little further in. The old whit one that I use all the time will not work with this case installed, no matter what you do. I probably assume the Square swiper might work.
Another Update to Swiper connection: The Note 3 is not supported yet!! :( :(
Cheers, Jon
There is one problem for me! The audio port thickness to the device does not allow use with my Intuit GoPayment swiper :( It does not go far enough in to make a good connection .... double :( :( Hope this info is helpful to somebody.
Cheers, Jon
I buy a case to protect from nicks and scratches,, normal wear and tear, not drops.. I treat my phones as if they were baby's,, and I don't drop them either. My spiegen came today and I love it. Looks and feels great. The camera lens is lifted a bit so the lens does not touch surface when I put phone down. Now I just have to put my temperd glass screen protector on and this baby is done.
Grr. Received my Neo Hybrid today and it has a bend/blemish around the charge port. -_-
I know I need to put a case on my note 3 but I love the way the phone looks so much that it's hard to cover it up has anyone seen a case that resembles the normal shell
Yes, the one I put on. I posted pics. At first glance my phone looks like there is no case on
Yeah but with the Ultra Fit you basically are replacing the Notes new, grippy, improved back with the Note 2's scratch- attracting, slick plasticky finish.
You get protection, but lose the benefits. I've got one too and am sending it back.
nivea531
