Galaxy Note 3 - Who is getting wireless charging kit/case for their note 3?
Be weary of those charging receiver pads. I bought one for my S4 (thinnest one rated on the forums) and it still made the back of my case bulge out.
Would there be any benefit other than perhaps reliability to getting the thicker official wireless charging cover over getting a receiver like the one linked which can fit under the stock back cover? Like does the official one charge faster?
I have bought 3 of those charging pads. One for my night table, one for my home working table and one for my office table. My phone is most of the time charging, which I think is one of the main reasons to get the QI in the first place (the other reason is the regular usb connector).
I ordered couple of cases too, but haven't received them, so I don't know how they work if at all. I have high hopes of this one.
my wife has a S4 and i have the N3 and we have been discussing getting wireless charging kits for them.
fitting in a case is a real concern for me.
if they don't fit, we will not be getting them. simple as.
I bought an induction coil for my note 3 that is compatible with my Palm puck charger. I don't mind slower charging as I use this for overnight anyways.. faster charging usually kills a battery faster. Once I was used to the wireless charging on my palm pre.. I couldn't go back. I also don't want to wear out my usb 3 micro port.
Anybody know of a case that will fit with the thicker induction charger back? I'm contemplating using just a bumper to allow for the thicker induction charging back.
Has anyone that's purchased from Mobilefun received thier order and found the back cover didn't click/lock into place on the right side from the power button down?
Have yet to receive mine but will post when I do if that's the case with mine
I'm liking the Induction coil that works with the Palm puck charger. I can use the original backing that came with the phone, no added bulk, and phone charges relatively fast.. about 4 hours which isn't bad for wireless charging. Only thing is the puck is a bit small so you have to adjust it to sit properly on it. I think if I use a case it might not work anymore. I think i'll just not use a case because I like not having to plug the phone in.
I've ordered charging pads too so I can go back to using the case I bought.
sellhousefastmke
