Galaxy s3 bench tests
Man i cant even return it as we're ripping off the hire purchase shop :(
The phone does fly but phones are gettin better n dont want mine falling behind in a years time n not bein able to handle apps.
Might take out insurance and "lose" it,..
Unbranded international s3 with Official JB. Paisley, Slotland, Western Europe :beer:
Since update to JB my score is lower on antutu
My score is higher on vellamo html5
From 1590 to 1761
GT-I9300 quad :cool:
This is my antutu score
post yours so I can see your CPU power
I know mine is like 89XX :(
Man this is crap. Gona root, do a back up n do insurance job. Jst hope i dont get hit with one with the bad glass.....
Should really have tested before reinstalling apps..
If u look at the dna bench tests I posted it lists s3 antutu as 10700 so my s3 and alot of other peoples are scoring over 12000 why?
I got OTA JB upgrade so s3 owners with same upgrade can't blame lower scores on upgrade
maybe its hardware difference a component was fitted to some models after a certain time which boosts score in some bench tests
If u haven't got a computer but wonder what your phones video and audio performance is like
my s3 quad standard 720p HD video + audio bitrate figures
So what's your video + audio figures like on your phone
find out download vid trim from Google playstore select your video on the app and it gives u a stats page like the ones I've posted so screenshot it and post it on here
Il giv it a try later. still in a huff that my s3 is a dud lol.
Gona flash it next week and if it dont improve, ill take out insurance for a month and "lose" the thing :)
Funky, you bring up a good point above. I didn't reboot my phone prior to running the tests. To be a bit more scientific about it, I should have rebooted each time prior to running a test under the same conditions. Rebooting is a good best practice, though, and helps to clear any non-persistent stuff in cache and thereby eliminate "warm cache" side effects, as well as knock down any background processes.
Your second test comes in somewhat above my Power Save Enable run, but approximately 22% lower than the Power Save Disable run. Given both our S3's had the full #Core running for the Power Save Disable, then the delta could fall into a few areas like: JellyBean is more resource intensive, Vellamo may be more optimized for ICS and thus run faster and yield better results, or that some of the workloads in the Metal suite perform better when more system memory is present, or the memory subsystems between our phone versions vary in bus speed (certainly do in capacity). Its likely a combination of all four areas noted (and probably more). Take Stream for example. Stream is all about measuring and understanding memory bandwidth (summarized from STREAM Benchmark Reference Information). Stream puts sufficient load on the system so that as work moves beyond the CPU local cache and into main memory, systems with less main memory may struggle in such cases.
So, the above may account for some of the differences. I'm also not clear at this point if the Metal Stream (is that a rock band by chance?) is executing as a single or multithreaded process. In either case it may be that for the memory intensive parts of Vellamo (or any micro benchmark or synthetic workload mixture) the International S3 may not have enough system memory to support all four cores. This is probably only a worry in cases with more extreme utilization patterns and multi-threaded memory intensive workloads.
Thought more on this and I left out another important consideration in the (and probably more) area. The International and US versions are in my opinion actually different phones, so a direct apple to apple benchmark comparison may not be possible.
If all of the information listed here Samsung Galaxy S III - Wikipedia, the free encyclopedia is correct, the International and US versions have different CPU (quantity and vendor), chipsets (SOC), and GPU.
Still cool to see the various results being posted, and the mystery with Funky's phone is interesting.
Yeah we're Exinos and youre Qualcam.
My mystery is pissin me off lol, i was gettin high scores on ICS. The phone feels faster with JB but that couldt just be placaebo...
Gona try a custom rom though 1ce i get laptop running... still unsure if i want cyanogen or a pure vanilla JB rom yet.......
...aparently Samsung have an 8core Exynos chipset ready but its unclear if the s4 will get it or a tablet 1st.....
SD card tester from Google playstore
my s3 phones SD card speed +
extsdcard sandisk 32gb class 10 UHS-1
GT-I9300 quad JB :cool:
EasyTap
