Galaxy S4 *32GB* In Stores When Do You Think???
Now that you can move apps to SD card I don't think there's a need for a 32Gb model...
Do some research and you'll find that the complete app isn't moved to the SD card. Granted, you get a portion of the app but it's not like it moves the entire app to free up the space.
I think all the new smartphones should be 32gb at a minimum.
Really??? From this line of thinking, there should never be a 64gb, if there is no need for a 32gb!!!
Just because you don't want it, doesn't mean the majority of other users do not want or have a need for more internal memory..
Just my opinion of your opinion.. ;)
App on an SD card is not the same as app on internal memory.
SD cards are slow and unreliable. They are made of the cheapest NAND memory you can find.
Google wants nothing to do with them and Google apps like Google Music do not work with them
The only thing I would use one for is to put a bunch of music on that can easily be replaced if the card dies. I wouldn't store anything important on one or put apps on one.
amktmalik02313
