Galaxy S4: Battery Drain
melmc1403
153
Hey!
My S4 had an update yesterday (think it's maybe for stability or something as it's still on 4.3). Ever since, my battery has been draining really fast. Anyone else on the same boat?
Thanks
Mel
Sent from my GT-I9505 using AC Forums mobile app
Re: Battery Drain
Were you able to see if anything was causing the battery drain? I noticed that every once in a while that Google Play Services kills my battery.
Re: Battery Drain
If you dont use it, turn of the 4G/LTE.
Mine was turned on after the latest update.
Re: Battery Drain
I checked the battery status and there's nothing outta the ordinary draining it but since this update it's draining really quickly. Help! x
Re: Battery Drain
my s4 went from 100% to 1% in 8 hours, most of that time the phone was in flight mode as i knew i was in a poor signal area. Any ideas? nothing obvious on the battery use page:(
liquidsnake757
