[GALAXY S4] Help with 'disabled by administrator encryption policy, or credential storage'
Perfect, this scenario worked for me and I was pulling my hair out trying to change my lock screen from a pattern to "none". Clearing credentials helped me get to the grayed out menus.
I tried to go and clear the cradentials and that area was greyed out preventing me from clearing them, and this is after I have went and unchecked all of the device administrators. and I was able to decrypt my sd card as well. I am still unable to have access to the other password options??
you must unlock/decrypt SD card the SIM card and the phone encryption. they all must be off/decrypted if not u must put password and only the password everytime.
Can't clear credentials, it's grayed out. I do not have any encryption on sd card or sim card. Now what?
I had the same problem after using FoxFi.
Clicking ?clear credentials? worked. Thanks for the advice.
Clear Credentials tab is not showing on my anroid some one plz help i have done first step of device administrator
Wen ur device encryption had been disabled u can change it from setting--display--lock sreen--u can change here...
I am having the same issue. I removed all the administrators but have not cleared credentials. What issues will come up when I clear credentials? I too do not want to lose anything, ie pics etc. Or is it that I will lose access to certain apps??
Hi mholmes1234 ,
i have Samung S4 mobile.
even i am also facing same problem what you are talking about.
can you please share me steps which you have used to over come the issue.
cinemacritic
