Galaxy S5: Is any replacement battery better than the original?
K83476552
7
I see on ebay plenty of replacement batteries with a higher mAh rating than the original one, but I guess not all of them are really better than Samsung's.
Do you have any suggestions on a really good replacement that provide at least 25% more battery life?
Thanks!
Re: Is any replacement battery better than the original?
Thanks!
Im positive that if there was a high capacity battery available then Samsung would have put it into the S5. Assuming the batteries on Ebay are correct and they are a high mAh than the genuine Samsung battery then they will likely not be as safe or will be physically bigger or something. There is no reason for Samsung to have used a lower mAh battery than is currently available .
Personally I use my phone quite a lot and still never run the battery down to flat. Given how expensive the phone is it might be worth just buying a genuine replacement battery from Samsung. They are not cheap but at least you know you are putting a approved battery in instead of something that is going to fry the phone.
Hope I am allowed to post links on here ( Someone tell me if I am not )
Why not get one of these and buy a spare battery http://www.ebay.co.uk/itm/USB-Sync-Battery-Dock-Dual-Charger-Stand-for-Samsung-Galaxy-S5-SV-G900F-i9600-C3-/141265615256?_trksid=p2054897.l5661
You can carry a spare battery about and then charge both the phone and the extra battery in one go when you get home.
Just be careful with the non-oem type batteries on eBay. Just because is lists a higher capacity battery than oem, it doesn't mean it is. Lots of threads (not so much with the S5, but give it time) with the S3 and S4 where people have purchased generic type batteries. Made the device hot and they didn't last as long as the oem battery. My advice is to get a genuine replacement battery when they are available.
A third-party battery can also be unsafe and explode. Admittedly it is extremely rare, but if it happens and you are using a third party battery then Samsung would point the finger at the third party battery
dpham00, Android Central Moderator
Sent from my Verizon Samsung Galaxy Note 3
Yep, you are correct.
On a side note, I used a Hyperion battery with my S4 and I have to say they were pretty good.
I've learned my lesson throughout the years. Most batteries (even supposedly OEM) online are fake (not original) and low quality. The only ones that are original are direct (NOT 3rd party seller) from Amazon or the manufacturers themselves. This is only if you're looking for OEM batteries.
Very true. I usually buy batteries directly from Samsung using the 50% off coupon.
I had no idea Samsung had coupons! Thats good to know!
It is very good :) Anyone care to share that code :D
rXu3670
Sent from my Verizon Sansung Galaxy S III
There are a few quality aftermarket brands (I swear by Anker), but the no name stuff on eBay should be avoided. They may be 10 bucks or whatever, but from personal experience, they only last for a couple of months before dying.
Whenever you hear that someones phone blew up. I heard about 3 in the last 2 years. It was an aftermarket battery,
I have found, over the years, that Anker batteries are dependable and I have never had a problem with them.
rXu3670
Says no longer valid, Thanks anyway.
I did find this one, 10% off orders over ?50 NPR-14G-QKY-WSZ
Where can I buy an additional battery? It doesn't need to be better, same one is fine. Would the carrier sell the individual phone battery or best buy? I just want it as a back up
the issue with off brand batteries is the efficiency rating, purely examples... if the samsung battery is 90% efficient, then it actually puts out 90% of the rated value of mAh (leared all this researching extrenal battery packs and ended up with Anker due to this information), most off brand batteries provide 60%-80% efficiency, so would need to be at least 20% higher rated in mAh to give the same output.
Thanks!
No, but I have a Zerolemon it's pretty good still not as good as the original battery.
Yup! and if they don't listen.....let them learn the hard way.
All those knockoff batteries on Ebay with higher mah etc, are bunk. I tried on my S2 and it was no different then the stock battery even though rated higher, same for others on other phones. Someone on XDA even used a knockof 4k+ mah batter in the S5 and said there was little difference. Only thing that will work will be direct from Samsung replacement that's higher, like in the American S2 people were swapping in the high capacity battery for the Korean model available from Samsung but modifying the back case to fit it. Even the brand name aftermarket ones aren't any better for life then the direct Sammy ones, good as a replacement or backup but not for longer battery life.
I only get 3rd party batteries I trust... Like Anker batteries.
Sent from my T-Mobile Note 3 using AC Forums.
Prince08900
