Galaxy S5 Verizon September Update.
Verizon only had 4.4.2 , they never released a 4.4.3
The only upgrade they have released up to before today, IMO was a bad thing. It removed a lot of features that I used and now I can't get them back. I am thinking of going back to the original release version.
I won't let the update occur on 4.4.4 until a lot of folks have used it. In the past, VZW has always locked my phone up tighter, not made it better.
What did they remove? I can't remember anything that was taken away after the second to last update.
Finger print scanner animation when it is either accepted or denied is changed.
Downloading it now hope this doesn't screw up Nova launcher
Posted via Nexus 7 2013 or Galaxy S5
Please share what the interface changes are because I can't see them
They have butchered the smart remote app every time you open it a ad pops up for a show
The Visual Voicemail is crap. You are far better off with Google Voice. Verizon is forcing their tools down users throats because most know better. I wish there was a way to uninstall it completely.
I wish AT&T would hurry up with the update, they always wait so long.
Sent from my Galaxy S5 Active using Tapatalk
The "emergency call" button on the lock screen is now a swipe icon...
On mine, the fingerprint scanner seems to work a lot better now. Less hiccups
Sent from my SM-G900V using Tapatalk
The only thing I have noticed is that the fingerprint scanner works really good! This was my first time trying it on my GS5. I previously owned a iPhone 5s. I decided to give the fingerprint scanner a try and so far it's worked really good.
Fingerprint scanner is significantly better after update.
Noticed landscape capability on lock screen now
Bluetooth crackling and cutting out issue is gone
So far solid update..
ips gaming 88
