samsunggirl03
- Apr 18, 2015
- 5
- 0
- 0
I'm amused and annoyed at the growing concern over this. Such a modest difference and the comparisons done are so far from scientific that I'm laughing at anyone worried about which sensor they have. An accurate assessment would at least require multiple devices, not just one of each, and done under the exact same conditions. Even if there is more than one article about this, one person doing a "test" and another one doing the same does not constitute a reliable comparison worthy of outrage.
We have bigger problems to worry about, humans.
thats ridiculous. that also means that every single phone review would be void then since each reviewer probably only had one single phone to use.
the very first thing you can easily discern is the saturation is completely different with the sony sensor vs the isocell. this is on my calibrated retina macbook. this is also readily apparent in less lit areas as seen on the right side of the colourful transformer room where the isocell version looks dulled vs sony sensor.
as for bigger problems? this forum area is specifically about the s6. trying to argue by fallacy of relative privation does not change that.
im on rogers up here in canada. got the sony sensor on mine.
I just used the dial code. Are you sure you're including the initial star asterisk in front of it?I'm on Rogers as well but the phone code didn't work for me - got an error. How did you make the determination?
I just tried it using a Sprint phone and it doesn't work either.Dialing that code doesn't work on Verizon.
Used the Exif Viewer
Verizon Galaxy S6 Black Shappire 64 gb. Purchased May 2nd.
ISO CELL
Not sure how I feel about it though.
Here is an article explaining the difference between the 2..with pics
Here’s the difference between Samsung and Sony camera sensors on the Galaxy S6 and S6 edge - SamMobile
