Galaxy s7 screen won't rotate and setting is missing
  • Start date Start date
A
AC Question
It was working fine a few days ago suddenly my screen won't rotate and the setting to turn it on and off is gone.
It was happened to me also and it made me crazy, through a lot of searching and browsing to find out the solution, walay (arabic expression), I was so really got sucked on my ignorance and foolishness hahaha, it is easy that the "portrait" icon to be selected to make it auto rotate. I never think of it as the same in printing selection as "portrait" & "landscape" only. Well, it's just an easy folks. Select "portrait" to change it in "Auto rotate".
I had the same issue and it appeared to be a function of the most recent update.
The autorotate no longer appears under Settings \ Accessibility.
By the way, the icon may look more like a lock than a portrait, but this technique of pulling it down from the top does work.
THANK YOU!!! Don't you just love it when they push updates without information on what changed. I'd like to slap the the UI designer that thought this change was needed. I was about to go the hard reset route myself.
I dunno. Seemed obvious to me. Portrait mode vs landscape. Those were the terms used for screen orientation for at least 30 years now. When I saw the portrait toggle, to me it was like, oh nice, it changes icons if locked or auto.
At 1st I dint know where my quick setting rotate button went.. so the u so much for telling me about the portrait quick button that fixed my screen.. again THX💯👍😡
Yay the portrait thing suggested from Drsdarjr00 worked for me...
why would they name it portrait touch in the pull down settings and then change it to the rotate screen logo after the change??? very confusing
Rom1701
